MNSparky
- Minneapolis, MN
- Electrical Contractor - 2023 NEC
Here's a good one...
A tree fell on a service drop the other day and pulled the mast loose from the house, bending it all up. We went out and replaced just the mast because the meter base was not damaged, like we've done a bunch of times. The house had an old 60A fuse panel in it. The inspector called my guy that did the work and informed him that we needed to upgrade the service to 100A, along with the grounding system. His reasoning is we worked on the service so we now need to bring that component up to current standards.
I know that the code doesn't specifically require a single family dwelling to have a 100A service, just a main disconnect that is rated 100A. This is going to be my main argument point when I call this guy back tomorrow. Otherwise the code doesn't really address repairing broken components, right? Has anyone else dealt with this issue?
