wattruler1
- Electrician
Hello all, I have installed dozens of 30 and 50 amp residential main panel generator interlocks in the last couple years here in Texas. Today I did the same for a gentleman who wanted to power his panel with his 7.2 KW power boost generator on his hybrid Ford F150. I didn't do my due diligence, even though he did mention watching some concerning videos about this, and the truck's built in GFI protection will trip since the house panel has it's neutrals and grounds bonded together. I know now the error of my ways. The homeowner was really hoping for a solution not involving a transfer panel. Newer transfer panels that open the neutral would work. At least that is what my research has told me. But then you are limited to around 6 circuits and then stuck with them. My question (finally) is could I install a 3 pole main breaker switch before the panel to break the neutral and at the same time separate the grounds and neutrals in the panel and make it a sub panel as a solution ?
