Grouch1980
- New York, NY
We're looking at recess mounting a 120/208 volt panel into a wall (flush into the wall). It has 6 feet above it of 'dedicated electrical space' according to section 110 of the NEC. Above this 6 feet, figure 7 feet higher than the panel, there will be plumbing pipes going through the wall (water, gas, etc.). I'm assuming the drywall material that makes up the wall would not be considered 'protection' against leaks or breaks in the plumbing pipes? would any fire rated material encasing the plumbing penetrations be sufficient?
Thanks!
Thanks!
