wireday
- New England
- Master electrician
Is it OK to use these on stranded wire and receptacles?
Only way I ever hook up stranded to a recept
just a thought.. twist strands "counterclockwise" first.
pulls tight around screw, doesn't fan.
Show me one that says I can not.
Can someone show me a device listed for use with fork terminals?
Ditto just about all commercial grade receipts are made and listed for fork and some include ring terminals.Like this one from Hubbell?
http://ecatalog.hubbell-wiring.com/press/catalog/A-19.pdf
To me, even if you get a good twist on the wire and are able to secure it well under the screw, the potential for coming loose because the strands shift is higher than a crimp with a fork connector.
Whenever I see receptacles or switches terminated with forks, I think it looks like either a second career electrician or someone from outside of our trade trimmed it out.
