The output of a solar panel is a curve with amps on one axis and volts on the other. Even in full sun, if the load is higher, the voltage output is lower,and if the load is lower, the voltage is higher. There are devices, called Maximum Power Point Tracking charge controllers, that try to find the "maximum power point" by increasing and reducing the load to see if the power output goes up or down.
What does this mean for the subject instance? The higher Voc panel will experience the greater load and move further down the V curve (the value of V decreases from Voc to Isc) and the lower Voc panel will see less load and it will move up the V curve. The result is that the lower Voc panel will have a lower load on it, but the terminal voltages will all be the same.
Rattus asked about bypass diodes. Most have them already. They wouldn't apply here as V quickly falls from Voc at which point the lower voltage panel will get to contribute. This time of day (7:15AM CST) my array starts creeping up to 80VDC, then the charge controller wakes up, applies a load, and drags the array back down to 60VDC trying to charge batteries. It gives up, the array Voc goes back to 80VDC, and the cycle continues until the sun is actually up and the fog burns off.
As regards paralleling the panels in question, once you've added bypass diodes and connected them in parallel, get a 12V charge controller and hook them up to a 12V wet battery, and hook that up to an inverter -- free electricity! The panels will be held at or near 14.4VDC when there is no load on the inverter, and who knows where with a load.
