pvspencer63
- Kansas City KS
- Clean Energy Specialist
What is the formula for sizing a 30 HP Electric Oil Pump Jack motor in an Oil field? The system is off-grid.
480VWhat voltage?
As far as the branch circuit goes I'm guessing that it should be sized like any other motor branch circuit. According to T430.250 a 30 HP motor at 480 volts draws 40 amps. Maybe someone with PV experience can tell us what is required as far as the size of the system required to allow the motor to start and run.480V
Sizing the MOTOR? You already say it is 30HP, I don't understand the question.What is the formula for sizing a 30 HP Electric Oil Pump Jack motor in an Oil field? The system is off-grid.
