George:
This and ALL the others are tables. Right. And they contain values that we use in our day-to-day job, as mandatory. Isn't it? OK, VD is not mandatory, by NEC, except in the two cases you've quoted in that url.
I just wanted to know how you guys handle the notes in Table 9 (By the way, they are NOT FPN). So, if anyone cares about adjusting the values, I'll have to look for information in that issue anywhere else.
Do you know about any book, or paper that can help me with this: not the formulae, not the how's, but the why's?
That's one point of view; others tell you to do it.:-?
If resistance change, why not the reactance? Again, I don't think it is high level engineering, just plain aritmetic plus some trigonometry.:roll:
			georgestolz said:Take a look at 90.5. A table is just a table, there is no language to make us do anything about voltage drop in most circumstances.
A FPN (fine print note) is not an enforceable rule, it's just additional information.
georgestolz said:We do this solely because we want to, not because the rules say we must.
georgestolz said:Resistance changes with temperature changes. If you want a more accurate calculation, knowing the temperature that the resistance is taken is a good thing to know.
