scnkapc
- Northern Kentucky
Is a foyer and/or entry considered to be a hallway? I say no. And according to 210.52 (A) (2) they are required to have receptacles located within 6' from door on any wall space that is greater than 2'. Example: Front door leads into the dwelling. Next to the door there are fixed glass panels on each side with wing walls approx. 3' feet in length. The foyer/entry area is approx. 10' x 10' with a staircase opposite the front door and open on each side-one opening to the dining room and one opening to the living room. Past the staircase leads into the kitchen. Are receptacles required within the wall spaces next to the front door or is it a hallway and only required to have a receptacle on the wall next to the stairway across from the front door?
