puckman
- ridgewood, n.j.
Has anyone replaced the inside of fpe panels in high rise buildings ? The panel is a riser panel with 2 other apts. using the same feed, for a total of 3 apts. The panel is a 12 circuit 100amp. Cat# r? 104-12 . uses na and nc breakers I called eaton ch and they said the panel dimenions were to small for an interior replacent. Any ideas on a fix ? Can't remove panel .
