bilwei
- Lufkin, Texas
I have an Industrial client with two large free standing bridge cranes. These bridge cranes are outdoors. They are approximately 700' length, x 70' width x 55' height. They are experiencing VFD and other electrical component failure due to lightning strikes. They were built in the early 1970. There have been upgrades with the VFDs and other electrical components thru the years. However, they have not installed a 4th bus for an equipment ground as required by the NEC. Besides the 4th equipment ground bus issue, I cannot find any sort of lightning, grounding or bonding system protection on the structure. With the exception of the equipment ground (#4 awg) brought in with the power feeder to the service disconnect and mounted on the structure. I need some information (literature, published standards, etc.) for my knowledge base and to best advise my client on actions that need to be resolved immediately with respect to lightning, grounding and bonding.
The only way the structure is earthed is through the vertical supports, which are supported on concrete pilings.
In this situation, there are some dangerous touch potential electrical hazards not to mention the problems noted above.
