Re: Freq drives/motors
73,
you should consider what type of task you are trying to accomplish. there are different drives designed to function at high and low speeds. a "static drive" is capable of running at low speeds or even at stop for long periods of time without any problems. in a large process plant a motor was coupled up to a gear box about the size of a volkswagon. the function was to turn a shaft ten turns in one direction and then reverse itself and turn ten turns in the reverse direction. we removed the motor and gear box. connected a static motor directly to the shaft. programmed the static inverter and energized the system. it would run all day ---ten turns one way then ten turns in the opposite direction -- same torque as the gear box and you couldn't feel any heat on the motor frame. it had fans on the motor ends to carry off any heat and they ran on temperature stats. the old system had a motor running at 1750 rpm all day.
we have used these static inverters in printing presses with good results --built in breaks ---no brushes or speed control problems.... we have had standard motors fail when connected to drives --- they should be "drive rated motors" --- the voltages produced by the drive is usually twice the normal voltage of an across the line operation. they are more efficient and will pay for themselves in short order.
we will see cable less elevator cars ---static drives will be geared directly to the elevator shaft rails - they will be more accurate than cable cars and of course more efficient....
