I recently posted a couple of pictures of a 400 amp fused disconnect with "C" clamps on the fuse holder. Well I went back there today to get a second look and work up a plan of attack. First is, I did a quick IR scan of the fuse holders, at the "c" clamps 85 degrees F. On the discolored (no "c" clamp) fuse holder 125 degree F. These temp. readings were at 10:30 a.m. about an hour before the heavy loads will start to occur. There is 10 units tapped off of this disconnect (vintage 1959) two of the units have 200 amp 3/0 feeders, the rest very about 125 each. I doubt anyone has done a load calculation since 1959, let alone pull a permit for electrical work.
