det_wireman
- Detroit, Michigan
I have a 460V, 3-phase disconnect and the fuse clips inside are made for Bussmann FRS- R40A through FRS-R60A fuse sizes. I want to use FRS-R20A fuses in this disconnect. The feeder to this disconnect is #6AWG CU protected by 60A fuses. Do they make a fuse clip reducer that would allow me to use the smaller FRS-R20A fuses? I need to protect a piece of equipment that will be powered from this fused disconnect. I searched the web with no hits that helped me out. Appreciate any info/advice you could give me.
