Alwayslearningelec
- NJ
- Estimator
Is it code to power fire smoke dampers from an emergency panel? They always seem to be powered from an EM panel. Thanks
You would also need to look at the NYC code amendments because hg works in NYC.The op asked if it were code. I looked thru IFC, IMC, IBC and not required to be on EM. Now smoke control as in stair press system yes. I did not look at NFPA 72
Agreed I didn’t even think about that.You would also need to look at the NYC code amendments because hg works in NYC.
