We have some small (<10 HP) water pumps fed by GE/Fuji drives.
We have historically had issues where - when supply power from utility cycles on/off quickly (i assume short enough that the pump is still coasting down when power is restored, the drives fault on OU2 - overvoltage during deceleration. Requires power down to reset the drive.
Are any of the VFD experts familiar with these drives and whether there is a parameter that should / can be adjusted to prevent this overvoltage fault?
