For industrial machinery, the NEC requires an FLA marking on the machine nameplate, and that the value "shall not be less than the sum of the full-load currents required for all motors and other equipment that may be in operation at the same time under normal conditions of use."
Large, complex machinery may have many, many loads fed from its internal power distribution system (e.g., controllers, power supplies, robots, etc...). Each of these sub-systems is usually a stand-alone commercial product with a nameplate of its own indicating its own FLA rating.
More often than not, such large complex machinery is not operated with all of its sub-systems running at full power (e.g., all set to '10'). In typical operation it may be that many are set at 8, most at 5 and a few at 2 (for example).
Does the 'may' in 'may be in operation at the same time' require that one consider what *could* happen even if it is not how the machine would ever, realistically, be operated, or is it acceptable to take some emperical measurements for a 'typical' operating scenario and set the nameplate FLA based on that?
Is there any commonaly accepted position paper for US electrical inspectors on this point?
The issue of course is whoever installs the machine has to design thier infrastructure to support the nameplate FLA. If a machine nameplate FLA must be determined by the simple addition of sub-system FLA's, then there is possibility for great waste (unneeded current carrying capability). If a machine nameplate FLA can be set by some more emperical method (e.g., current draw during intended use), then sensible infrastructure is possible.
Thanks for any insight/advice.
