Furniture feed multi conductor sharing neutral
JJWalecka
New England
I have a furniture feed requiring four phases and two neutrals
I have four existing 12/2 at a central location that I was hoping to box and reuse use for the furniture feeds.
Because the branch circuit will be MC cable....is there an issue using two 12/2 feeding the two circuits that would be sharing a neutral...the shared neutral would be in two different cables. If I was using Romex and a plastic box I wouldn't worry but because I'm using MC cable I'm wondering if that is code compliant
Shared neutral in same raceway or cable code compliant
