Davebones
- North Of Tampa Fl
I replaced a bad contactor for a 150 hp , 480v motor . Reconnected everything and was doing a quick megger to verify everything was safe to power back up . Noticed that I was reading .8 meg ohms at 500 v to ground each leg . Couldn't find any issue with anything I did , so I isolated the fuse block . The fuse block is a Littlefuse ( LR60400-3CR 400 amp ) fuse block . The fuse block is reading .8 meg to ground . Fuse block is in a clean cabinet not sure why I'm seeing this low of reading . Any thoughts on this ...
