Errorsfordays
- USA
- Wind Turbine Technician
This circuit consists of a pad mount transformer stepping down 34.5kV to 12kV, a 12kV switch-gear, and a secondary transformer stepping down 12kV to 400V and 690V. One fuse keeps blowing on a single phase of the 690V side every time a moderate load is put on it. I have watched the voltage on all three phases while the fuse blows, and there are no voltage drops out of tolerance. Some of the more sensitive components on that line are also burning up intermittently. I have tested every component on that line, and megged the transformer. My question is: Is it possible for a loose connection in the pad mount or switch-gear upstream from the secondary transformer to trip that fuse? With the clock ticking on this fault, I don't want to go down that rabbit hole if its not possible.
