A power transformer has a capacity and ratings of 4.0/5.0MVA OA/FA cooling, 34.5kV-480Y/277V, 6.5% IZ, Oil Filled, 3-phase, 60Hz. The designer specifies 160A size of fuse for the primary Load Break Switch of the above transformer. Our problem right now is, the end user approved an specific brand of LBS with only 100A maximum available at 34.5kV application. This LBS manufacturer do not allow switchgear manufacturers to design their fuses in parallel so that we can choose 2 x 80A in order to follow the 160A specs. To be more specific, the brand of LBS is AREVA (Formerly Alstom), Fuse is SIBA.
Hope you can help us on this. Thanks
