victor.cherkashi
- NYC, NY
I have to connect (4) sets 4#400MCM on the load side of a disconnect because of tap rules, so I specified EATON DH327FGK (800A. 3-pole). I need only 125 Amp feeder downstream of the disconnect, but the contractor says he can't fit/install 125 Amp fuses into 800A disconnect. I expected that fuse reducer can be used for almost any size.
I left a question for the support team on the EATON website but no response so far.
www.eaton.com
Any input will be appreciated
DH327FGK | Eaton enhanced visible blade single-throw fused safety switch | Eaton
DH327FGK - Eaton Enhanced visible blade single-throw safety switch, 800 A, NEMA 1, Painted steel, Class L, Fusible without neutral, Three-pole, Three-wire, 240 V, Max Hp: 100 hp (3PH @Std), (4)#1/0-(4)750 kcmil Al
