Brandon Loyd
Using values 45, 51, 59.
NETA MTS says to investigate fuse-resistance values that deviate from each other by more than 15 percent. How would you calculate this?
For contact and bolted connection resistance NETA is very clear saying to investigate values...by more than 50% of lowest value. Easy math 45 + 50% = 67.5. All values are within 50%. No problem.
For fuses, would I add 15% to the lowest value, deduct 15% from the highest value, or find the average then go +/- 15% from the average?
I can't seem to find a definitive answer anywhere, so hoping someone here with NETA/ANSI expertise can help. Thanks in advance!
