I know I saw a thread about this topic not too long ago, but can't find it using the search function.
Looking for opinions/requirements for a nameplate that says "Max Fuse Size"
This is a commercial washer, 3-phase. Nameplate says Running Amps - 9.0, Max Fuse Size - FRN 20.
The reason I'm asking is that there's not a good spot for a disconnect that is "within site of" the appliance and I was contemplating using a circuit breaker with a lockout as the disconnecting means. The panel is about 35 feet from washer but not within sight (view is blocked by another appliance (commercial dryer)).
The panel is a 3-phase Siemens QP style panel. I could get a permanently installed breaker lockout just like used in residential for a water heater if the CB is acceptable as a means of disconnect given the nameplate.
