prajwal2341995
- New Jersey
- Electrical Engineer
Hello,
I am working on a project, and we need to add the external fuses to VT's/PT's on the meter cluster shown in the image (link).
As per my calculation the fuse sizes are as per the spec sheet I have attached for VT's:
VA Burden= 75VA, IC Voltage=12.45KV
Pri: 75/(12470*1.732)= 0.0034 A = 1Amp fuse
Sec: 75/120= 0.625= 1Amp or 5Amp fuse
Link for image -- https://ibb.co/y0PY3pR
Link for Cutsheet- https://ibb.co/n6YJPjF
My plan is using the fuse cutouts of (3)1Amp, 12.47 KV rated will be installed on the cross arm on the pole and (3)5Amp, 120V rated in the fuse box.
Can anyone please guide me if I am on correct path for this issue? If not, can anyone guide me how we can make these connections happen?
