Fuses for C1D2
Manufactures like Weidmuller are know providing Class 1 Division 2 rated fuse terminals but they are only approved with dummy fuses (slugs).
Does anyone know of any testing that has been done sucessfully using the new Weidmuller C1D2 WSI 4/2 fuse holder with a Bussman 1/4 x 1 1/4 fuse like the AGC with the B option (Board washable Hermetically Sealed)?
Thanks,
This is marketing drivel. The fuse blocks never needed to be specifically identifed for Division 2. The fuses did for some applications, but not all.
You are correct it is all marketing,I called Bussman to find out about their board washable "HermeticallySealed" fuses, and of course they do not support using these fuses for C1D2 hazardous areas. So now we have manufactures making the so called C1 D2 fuseholders and nobody in the industry makes a 1 1/4 x 1/4 fuse to use with it, how convenient.
Same issue with the GMA (5x20mm) - and they're used by the thousands in C1D2.
Depending on the application, if they are hermetically sealed, they are already suitable for Class I, Division 2.
