There is a 100A 3 phase disconnect that keeps blowing a 100A fuse on phase A. The 3 phases only carry 50-60 Amps each. The fuse holds for about 3 days then the customer calls and says the fuse has blown again. There are no signs of excessive heat in the disconnect or the 100A panel that it feeds. The 100A panel it feeds has a main breaker which never trips, its allways the phase A 100A fuse that blows. Could this be an AC condensor or a walk in cooler condensor causing the problem? Any ideas would be appreciated.
