djcrzysounds@yahoo.com
- Scranton, Pa
Never had this happen.... a 240VoltPrimary 120Volt Secondary Transformer for inside a Motor Starter Control Cabinet is drawing more then the rated fuse installed by the factory. I've never used the brand that was purchased. It was provided by the fitters for a 'Vaporizing Pump'. Box has its own buttons for Start/Stop and an E-Stop. However there is an additional Start/Stop switch I installed. Unit worked fine when it was installed, however 2 days later I get a call that it isn't working. I checked the fuses and both on the primary side were blown. I put the ammeter on it and replaced the fuse with a 2Amp instead of the 1 Amp in there and it was drawing app. 1.4 Amps. I do not have a VA rating for the transformer and I have not heard from the Control Box Manufacturer yet.
I've never seen this before... Any suggestions or just install a 1.5 or 2 Amp fuse and it will be fine?
