Does a code violation exist here in regards to fuse size?
I have an AC disconnect that is being used as a disconnecting means for an Inverter. The inverter is being fed from a 2 pole 20a breaker 220v. The inverter doesn't require a fused disconnect, a non fused would have been suffice. Our shop sent out the fused disco along with 2 30a fuses and expects us to use them. Is there a violation?
