I have the small glass fuses for different things at work. What is the the reason that a fuse rated at 10 amps 24volt will blow in a machine running on 120volts. A 10 amp fuse rated correctly for 120 volts will work correctly and not blow. Yes I know use the right fuse, but seriously whats the teachnical differance?
