Joe Corbin
- Key West Florida
- Master Electrician
We are planning on using a 500 KVA pad mounted transformer for temporary start up and check out of some of the equipment in a water treatment plant. The permanent transformers are going to be way late on delivery 2- 3000 KVA stainless steel, expoxy coated, etc. The primary service is 13,800 volts the secondary is 480/277V. What rating should the primary MV disconnect be and also the 480v secondary disconnect? After the disconnect we will be feeding temporarily into the main distribution switch.
