mdshunk
- Right here.
If I was to use a buck-boost transformer (120/240 primary, 12/24 secondary) to power many banks of low voltage accent lighting, am I required to fuse each conductor run from the secondary side?
You need to use a listed low voltage lighting transformer.411.2 Definition.
Lighting Systems Operating at 30 Volts or Less. A lighting system consisting of an isolating power supply operating at 30 volts (42.4 volts peak) or less, under any load condition, with one or more secondary circuits, each limited to 25 amperes maximum, supplying luminaires (lighting fixtures) and associated equipment identified for the use.
411.3 Listing Required.
Lighting systems operating at 30 volts or less shall be listed for the purpose.
