Where does it say that you must install these fittings? Class 1 div 2 We typically install a uny, lby, then a seal out of instuments. From there it varies per customer, marine cable w/ clx connectors, metalic braided flex, but generally transition to seal tight (18") then back to conduit. Sealing before entering into a plc cabinet. Are Form 7 fittings not acceptable in this conduit system? I've seen conduit systems on pump pads both ways.
Sent from my SAMSUNG-SM-G530A using Tapatalk
