darunedefig
- HV, New York
- Electrician
I am at a job that the 200A Main service panel in garage has grounds and neutrals connected. There are feed-thru lugs at opposite end of main 200A breaker. The conductors from the feed-thru lugs are 200A rated and go to the lugs of a 200A main lug only panel that is 20' away in basement. The MLO panel has several grounds and neutrals connected together on same bar. Would we call this MLO panel a subpanel and thus the grounds and neutrals should be separated?
I guess the thinking was that the MLO panel is just a continuation of busbar of the main panel.
