G&W 6 Way Link Box
robbyrad
Kansas City MO
I'm trying to identify a piece of electrical equipment on a current project. The name plate says "G&W 7.5 KV 3 Pole 6 Way Link Box 500 AMP #UES5472J0-1 CAT. AL6355M. Building was constructed in 1973. This is in a main electric room at the penthouse level of a 33 story office building. Within the room are 4160V substations, dry type transformers, and 480/277v 3 phase 4 wire switch gear. The equipment is in metal enclosure with bolts on top at fairly close spacing, and there appears to be a small amount of oil or other substance leaking out of the bottom. I have attached a couple of photos. Thanks for any assistance.
By analogy to a three way splitter being one input and three outputs, I would throw the SWAG that the box contains a three phase bus array with one set of input terminals and six sets of output terminals. And no disconnects or OCPD.
Cable Tap Box
Cable Tap Box
Thank you for your input.
John 120/240, I also found G&W electric, but I couldn't find anything on their website that looked anything like my photographs...
GoldDigger, that sounds pretty reasonable... I found the original plans from 1973 and it is labeled "cable tap box #2". Original one-line shows two taps going in and four taps going out, which may explain the "6-Way" on the name plate label.
