Galv Steel On Coated Conduit
Alwayslearningelec
NJ
Estimator
Can pvc coated galvanized conduit be in contact with hot dip galvanized steel? Asking because it's an outdoor application but they want it supported by hot dip galv steel. Always usually see stainless steel.
don_resqcapt19
Illinois
retired electrician
If the specs are calling for hot dipped galvanizing, be very careful...that spec often calls for the part to be hot dipped after it is cut and/or fabricated. That can be costly.
If you want to use stainless, you would need to submit an RFI or something to CYA.
