Garage door button problem
GerryB
The HO has a standard control in her garage and a doorbell insert button in a 4gang box with 3 light switches in the house. She said it worked intermittently and bought a new insert for it. It worked twice then stopped and even the one in the garage wouldn't work. My question is after ringing out the wire and trying another button I had to put the old one back. The new ones I tried were the lighted kind, the old one wasn't. Could that be the problem? Thanks
GerryB
Ok, didn't know about the war, I thought maybe you were referring to interference from the line wires. This was existing, I wouldn't have done it, but I did use one of those 2-gang boxes with the divider for power and low voltage. How about this though, an addition I did recently I ran the t-stat wire up from the basement through the same hole as a line wire and the inspector made me change it.
texie
Fort Collins, Colorado
Electrician, Contractor, Inspector
Divider/barrier same thing. As long as it is there, the door button is fine with the light switches. Now the thermo cable in the same hole as the nm cable is another story. While not the best practice, I don't believe it is a code violation.
