Garage Door Control Button
Michael15956
NE Ohio
I was wondering if a lighted garage door control button has two sets of contacts. One for normally closed for the light and one normally opened for the motor?
Michael15956 said:
Thanks Ken, that helps. Does the one single button ones have a PC board also?
Not that I'm aware of. The electronics in the operator determine what needs to be done (raise, lower or reverse) when you push it. I think I've installed doorbell buttons in addition to the 3-button jobs that come with the operator.
If you use a doorbell button with a light, you may have problems.
I remember one several years ago that caused the door to go up and down.
Unlighted button solved the problem.
Simply enough, they just place a light across the contacts, like a lighted doorbell button. The current of the light flows through the load, but is low enough to not trigger the electronics. An LED uses much less current than an incandescent bulb.
Thanks Larry,
I took an Ohm reading across a one button garage door opener and received a low resistance reading when the contacts were opened and closed. Would that be because of the light load across the contacts? The button did not appear to have any electronics at all.
Michael15956 said:
Thanks Larry,
That is correct. The light will give you an ohm reading otherwise it is just a momentary contact switch. I also have had a problem with the lighted button many years ago. I just pulled out the ligh and the switch worked fine. Some units insist they must have a special switch, probably to control the light on the door separately--- not sure
Dennis Alwon said:
A triumvirate of murine rodents totally devoid of ophthalmic activity was observed in a state of rapid locomotion in pursuit of an agriculturalist?s uxorial adjunct.
Three Blind Mice?
Larry Fine
Larry Fine
Larry, I'm trying to elicit another response from you to my confusion over 130vdc and the division of same in the field. 130vdc at the battery bank is obvious, but the division when testing in the field to 65vdc is still confusing. Considering there is no center tap on the battery bank. Thanks, Lee
