stew
- federal way,washington
A bit new at this type of work. Large garge 24x48. Frome basement below grade short LB out the wall from main panel to trench about 50 ft to garage thru the wall 20 ft to panel all in pvc. 60 amp circuit. Feed a 125 amp subpanel customer supplied. 2 20 am outlet circuits around the walls . 8 quads. 1 20 amp gfci to an outside quad. one 20 amp circuit for 2 outside security lites and an entry lit. 3 switches( 2for the inside liting and one for the entry) 20 ft run to a 3.5 hp compressor 240 v mount a small 60 amp cheapie 60 amp breaker box at the comp. 60 amp welder circuit a few feet from the panel with 50 amp outlwe. 1 60 amp c/h breaker at the main panel 2 60 amp breakers in the sub along with 4 20 amp. all Square d qo. # 12 romex for lites and plugs. Flex to compressor and welder outlet. Compressor hp is extrapolated from nameplate amps of 24 fla. no hp shown. will require # 10 for its branch. I am supplying everthing including a ground rod and wire all except the panel which the customer has. How would others have bid this job?
[ March 17, 2005, 11:04 AM: Message edited by: stew ]
