Garage Subpanel and 3way
Dexie123
Running a subpanel out to a garage. Can I encorporate a three way in the same conduit that is feeding the sub?
Thanks
You should look into conductor derating if there are more than 3 CCC's in the raceway.
I will say again-- yes you can. I will add that you may have issues with 225.30 but generally that is overlooked. Just install the switch next to the main disco at both buildings.
