Garage subpanel load
Jimmyk06
New User
Minnesota
Maintenance
I'm in the process of getting a detached 24x24 garage built. I have a 100 amp main in the house and plan on installing a sub panel in the garage. It will be about a 80'-100' run. Because of cost and availability, it was better just to get a 100 amp main circuit breaker rated panel. But I don't think I will need close to that load capacity so to save money on the wiring run I'm planning on feeding it with a 60 amp breaker from the house. I plan on having 1 240v 40A circuit for 7500 watt electric heater (that will only be used sporadically in winter), 1 15A lighting circuit, 3 20A receptacle circuits, 1 20A circuit for outdoor light and recept by door. The only permanent motor would be a garage door opener. Would a 60A feed be enough?
I am closing this thread in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
