kjw444
- detroit, mi
Just wondering what your preferred method is for this scenario? When running PVC underground into the garage to feed the panel do you:
A. Run the pipe directly into panel
B. Switch over to FMC then into panel
C. Pipe into a junction box then use ser cable
I know this thread could go on for ever and there are a million different situations and limitations, but I was just curious as to what methods you guys use for a residential detached garage about 50 feet from the main panel, flat ground and no difficult obstacles. Personally I always go with A or B. As a side note UF is out of the question because the homeowner is a smart man and wants oversized PVC just in case for the future. Looking forward to seeing what you guys use!
