Jerseydaze
Is there any reason I can't hard wire a res kitchen disposal ?Or must it be cord and plug? Would a switch in a sink base count as a disconect?
There's no reason you can't wire it that way. However, in all probability you're not going to be the one servicing that disposal. That would mean a plumber or appliance service person will have to shut the switch off, unwire the unit and pull it out in order to work on it. Wouldn't it be easier to just cord & plug the unit so it can be removed easier to work on, not to mention relying on the ability of the plumber to properly and safely reconnect the unit ?Is there any reason I can't hard wire a res kitchen disposal ?Or must it be cord and plug? Would a switch in a sink base count as a disconect?
I always make them cord & plug for the reason I stated. Just thinking about the next guy who has to work on the unit. If you hard wire a GD or DW I believe you have to use a breaker lock unless you have a disconnect switch as the OP stated.Agree but then why do dishwashers and the like all not come cord and plug?
Leaving a service loop for a GD makes it so at least whoever has to unwire/wire it back up doesnt have to do so on their back inside a tight, cramped cabinet.
DW yes, unless there is a unit switch that disconnects all ungrounded conductors - but that is pretty unusual.I always make them cord & plug for the reason I stated. Just thinking about the next guy who has to work on the unit. If you hard wire a GD or DW I believe you have to use a breaker lock unless you have a disconnect switch as the OP stated.
They usually don't come with any dishes eitherAlmost always outlet. Typically I share with dishwasher and disposal. Outlet below sink. Makes it easy because usually the disposal and dishwash on site so i just put cord on and plumber can plug it in. Too many call backs for tripped breakers/doesn't work. Poor plumber electical skills. As far as dishwasher not having cord...does it have water supply line? Nope
LOL ???They usually don't come with any dishes either![]()
I agree. I have no problem with an experienced plumber making up the electrical connections on a garbage disposal swap out...If the plumber has to replace the GD there is no difference if he has to make a hard wired connection or reconnect a cord whip.
On the other hand, I don't ever want an electrician touching my plumbing.
Isn't that some form of an oxymoron :?I agree. I have no problem with an experienced plumber making up the electrical connections on a garbage disposal swap out.
Isn't that some form of an oxymoron :?![]()
