Garbage Disposal
neutral
Missouri
Hi
Is there a code article that would determine the location of the garbage disposal switch? Above the sink or in the cabinet?
Thanks
Charlie
neutral said:
Hi
Thanks
Charlie
It could be on the sink....
Air switch.
They've got these cool fiber-optic switches now that are real problem solvers. The appearance on the countertop is only about the size of a dime. Good for prep sinks in islands with no space for a snap switch and an air switch would be ugly. That said, "batch feed" disposals are good for where you don't have a switch too. They turn themselves on.
I suppose this would be where you would not want to chase your wedding ring down the drain.
neutral said:
Hi
Code wise the switch that is used as the controller can be anywhere, could be in the master bedroom.
The required disconnecting means must be within sight.
neutral said:
Hi
The required disconnecting means must be within sight of the motor.
What are you trying to say?
I'm curious now...remember who makes those Cool fiber optic switches?
That sounds like a code proposal I sent in one time about switch placement . Code panel stated switch placement was a design issue.:smile:
The interesting question here is if you have your head under the sink while working on the disposal is the switch on the counter within sight. I have been turned down for that reason but it was on a hot tub, With your head inside the space you could not see the disco so I get red tagged.
No its not. But a switch under the counter isn't within sight either when you have your hand inside the disposal trying to get that wedding ring.
My (very quiet) 3 year old son made that very obvious to me one day.
Name withheld by request.
