garrisonm1
- Maryland
Got a red flag today on inspection and still not sure where he came up with this. I have a indoor gas air handler unit that draws 9amps max. It state max fuse size of 20 amps. I ran #12 thhn to a single pole switch then down to the unit. This is fed off a 20 amp breaker in the panel. He told me I needed a fused disconnect at the unit instead of a single pole switch. I always used snap switchs for cases like this, of course I change it out, because that was the only thing holding up the job. Any code references or clarifacation on this.
He also mentioned it should be on an AFCI along with the outdoor unit?
