Gas cooktop power
ritelec
Jersey
Hello
Home owner is purchasing a gas cook top. Never installed one so looking on line for specs on several manufactures 36" tops
I figured I would just install a receptacle off the appliance circuit as like a regular gas oven/range for the ignition but it seams the manufactures are saying it is suggested the appliance be on it's own 15 amp circuit.
Is this normal? I mean it's just the ignition right ?
They also say the receptacle should not be gfci protected
That receptacle like other recpts even if it is behind a draw, like any other receptacle that is within in 6 ' of the sink , doesn't it have to be gfci protected ??? Then what?
Thanks
Thanks
Don't know of an exception in 210.8 (2014) that allows a "hidden" non gfci protected receptacle within 6 feet of sink in dwelling. If the range won't accept gfci, customer needs to get another or get the range loc moved outside of gfci perimeter.
