gas & electric
hi
i'm installing a fireplace blower motor receptacle for a gas fired insert. Is there a minimum distance between the receptacle and the gas line?
thanks
redhorserider
rcarroll
Nothing in the nec will prohibit your installation. Check the instructions, local ammenments, etc. I have never seen an issue with the gas line & power together in the insert. Hopefully there is no gas leak :smile: . But, someone would probably know that by now.
