A gas engine generator uses a reciprocating engine, powered by gas, no, not gasoline, natural or bottled gas. Example Jenbacher.what is the difference between these two?
as far as I know turbines are the fast (for gas turbines I speak) of all the turbines..
I don't know if it is still true, but many of the GE units (built here in Greenville SC) ran the turbine substantially faster than the generator with gears between. When I worked for Duke Power in the 70's, we had "free turbines" driven by the exhaust gasses of the gas turbine. The gas turbine speed was independent of the free turbine (which was connected to the generator and, IIRC, turned 1800 rpm. Waste heat from the free turbine outlet went to "heat recovery boilers" which made low temperature steam for our OLD steam turbine generators.Well, all the gas turbine generators I have seen spin at 3600 rpm just like steam turbines and piston engines.
You say that as if there was something newer available.The computer that kept everything in phase used MS-DOS 3.1 as an operating system.
Reciprocating prime movers ( gasoline, diesel. propane,natural gas etc.) spin up fast. They can be putting out power in 10 seconds or less.
Gas turbines take longer. Many minutes, longer time the bigger the machine is.
It's the reason you never see gas turbines as standby/emergency power sources.
Well, all the gas turbine generators I have seen spin at 3600 rpm just like steam turbines and piston engines. They were also huge, like 8 or 10 feet in diameter. I don't think a small turbine could run that slow. Things get much more complex when you are trying to make 60Hz AC with a generator that is not spinning at 3600 rpm, so complex that it is almost non-existent.
That trend may be coming to an end, though, as inverters are becoming more and more popular which allows for the frequency to be determined by the electronics, not the speed of the generator.
The GE Frame 6 gas turbines I worked with had a 32 MW capacity with turbines running at 5100 rpm and the generator running at 3600 rpm. The set-up needs only 10 minutes to reach full speed from a "cold start"
When I was a new grad off the EE school, I had the chance to work on a European GT; Brown Boveri 11L 15MW, 13.8 kV, single-shaft, 3600rpm unit. The unit ramps up to synch speed in 6-8 minutes and auto-synch to the system immediately!The GE Frame 6 gas turbines I worked with had a 32 MW capacity with turbines running at 5100 rpm and the generator running at 3600 rpm. The set-up needs only 10 minutes to reach full speed from a "cold start"
