gas fireplace not igniting
Stevenfyeager
United States, Indiana
electrical contractor
My customer says the gas fireplace sometimes does not light when using the wall switch. It worked fine today for me. I told her it is a gas appliance, and should call a plumber or HVAC. She said she had it serviced by a plumber and he said the problem is electrical and she should call an electrician. Help! I told her it's not a house voltage switch but a switch that sparks on its own in the unit. How can I help her?? Thank you.
Last fireplace I looked at had a battery operated igniter that just needed a new battery, but in this case the battery that was in it corroded the unit beyond repair so I was able to order a new one on the Internet after I located make/model on the igniter.
what type of fireplace is it. A standing pilot that a switch just opens the gas valve or does this switch actually ignite the flame?
Unfortunately a residential wireman (electrician) may not be qualified to diagnose and repair an electrical problem inside a listed appliance, and I would be reluctant to go inside the gas fireplace mechanism.
If no technician is available who knows the gas fireplace (more likely HVAC than plumber!) I might look up the model online and see if there is something simple like a battery needing replacement. And I would be willing to check the operation of the wall switch as long as it is not part of the fireplace assembly itself.
Do you know if it fails to spark or sparks with no ignition (leading to suspicion of the gas valve.) Also since there is no standing pilot to run a thermopile for electrical power there would have to be either a 24V AC supply, a battery, or a 120V supply with an internal control transformer. Try to find out which it is.
It's likely something simple.
Tell her it was your job to run 120 volts to the switch. That's where you stop.
Or ask her if she has the number on the paperwork that came with the unit. A fireplace installer likely installed it, even in Indiana.
And that is the end of the story. An Electrician should not go any farther than that, the liability if something should happen could be unimaginable.
Roger
Unfortunately I seem to get asked by several HVAC guys to help them with almost anything electrical on their appliances. Simple two and 4 wire 24 volt controls maybe they can handle, newer PC board controlled units often flash a code that helps them diagnose what component may need replaced, but outside of that, many are stumped really easily.
Gas fireplaces they GC or carpenters set the unit and build any surround, the HVAC guy connects the gas and any venting, but they all seem to think it is the electrician's job to connect most the optional components, so I seem to do that most of the time.
One thing that is common right away is it won't ignite, but on a new unit often the reason is you need to purge the air out of the gas line, and it will take forever for a pilot valve to purge it, so I end up cracking open the line to purge it because the HVAC guy is already been there and gone and they expect me to connect accessories and start it for the first time.
To OP if this happens to be a LP system and they had ran out of LP or had line open for any reason - it maybe didn't work because line wasn't purged but after you showed up it had eventually gotten purged and now it does work. (just one possibility)
tell her to call the place she bought it
they likely have a service tech or can recommend one
Majority of the ones I see came from a big box store, home center, etc. nobody on staff is really qualified to give service advice though.
Try calling a fireplace guy. I have trouble shot very simple or minor problems with these, a lot of the time is simply the battery pack is corroded and needs new batteries. Other major fail points are the igniters. I have no problem doing either repair, however past that, I refer the work to somebody who works on fireplaces for a living.
, edited to add... Neither plumbers nor HVAC guys should be messing around with a fireplace. call somebody who specializes in these type of repairs.
What leads you to believe there is no standing pilot? Many do have. Including mine.
A lot of these things have an ignitor now, no pilot light of old. The igniter likely is a "piezo" generator device; pushing the button stresses a component that generates a high voltage low current pulse that then goes to a spark gap device, like a spark plug, in the fireplace. Pushing that same button ALSO mechanically releases the gas valve in some of them, or if not, they have to turn the gas valve on first, then hit the ignitor and if it doesn't light in 10 seconds or so, the valve turns off for safety. So to try again, they must reset the valve and that can take upward of 15 minutes, depending on the design. They use the same thing in gas BBQs, that's how I learned how they work.
Either way, the device, although APPEARING to be "electrical" and creating an electrical spark, is not really something in our realm of electrical. It's not really plumbing either. 99.999% of the problems with piezo ignitors come down to being mechanical problems. I'm in the "call a fireplace guy" column.
Lots of good recommendations, best of which is "call a fireplace company".
I recently replaced a wireless remote setup (receiver and handheld) for my in-laws' fireplace. It was super easy, just a few spade clips and bought it on Amazon. Anything beyond this in a fireplace and I'd be calling a fireplace professional.
Sent from my Pixel XL using Tapatalk
"... a switch that sparks on it's own inside the unit" sounds a lot more like a spark igniter than a standing pilot.
Also energy regulations are making standing pilots few and far between in new units.
Quick story I'd like to add... as some of you know, I used to run Wastewater plants. The last one had incinerator, a 9 hearth furnace about 60 feet high. It had burners on most zones. These burners had fire eyes and Maxon valves. They could be set anywhere from barely a candle output to throwing a 20-foot flame across the furnace. Biggest fireplace I've ever seen in my life...
Ok, that didn't really have anything to do with this topic. .. what does is me attempting to light a portable propane heater winter before last without knowing exactly how it worked. I got it lit, and lost my eyebrows in the process... despite the fact I knew how commercial fireplaces and MY home fireplace worked, I did not know how THAT particular gas device worked.
Tl;dr: do not make assumptions when gas and electricity are involved.
Eta: I personally consider working on fireplaces a solid 10 on the liability scale. If you choose to do so, make sure your insurance covers any mistakes you might make. To reiterate the above, call a specialist on these problems.
My small fireplace has a standing pilot and thermopile that generates the power to run the gas valve. No 120v necessary unless you want the fan to run. A standard single pole switch makes the connection for the gas valve to open/close. Someday I will check out the connection at the gas valve because when I get down there to make sure I don't have it set to "pilot" I inadvertently wiggle those connections and "poof', I have fire. Imagine that. They look good. Someday I'll get around to it. Maybe.
I still see a lot of pilots in new units, with a spark igniter of some sort to light the pilot.
I think there are a couple reasons and the post below kind of leads into why to some extent. Other then use of a blower, you can still use during power outage. It is safer to light a pilot, and sense presence of pilot with a thermocouple then to directly ignite main burner with a spark igniter. Pilot can also be manually lit if necessary.
Haven't worked on one for a while, seems the last basically you turned it "on" and it was in standby mode with the pilot burning. Then further actions would turn on main gas valve, as long as there was proof of pilot.
Good call - I missed that!
I write this to (hopefully) add a little bit of information. I am a retired Mechanical Engineer and not an Electrician or Plumber). Our fireplace had the same intermittent problem. The fireplace has a standing (lit all of the time) pilot. The flame from the pilot light heats a thermocouple that provides millivolt power to the switch on the wall. Of course, this millivolt power opens the gas valve when the switch closes. I recently learned are while this switch LOOKS like a $4.00 rectangular decora switch it actually should be a more costly $20 millivolt switch probably with less resistance. Skytech sells this millivolt switch, a timer switch, or a remotely controlled switch for this application. Now, to be perfectly honest, i bought the special millivolt timer and the measured resistance across its internal switch but it didn't seem much different than a regular $4.00 decora switch. Still, I can imagine the Skytech switch has a genuine purpose beyond my understanding. While installing the timer, I decided to lightly sand the 15-year accumulation of residue (carbon?) off of the thermocouple. Since I replaced the switch and cleaned t
he thermocouple, the fireplace always starts. I suspect that my repair had more to do with cleaning the thermocouple off than changing the switch. Most repair guys (as noted by a previous writer) would replace the thermocouple (which is reasonable). This is is more of an a/c or fireplace repair guy's area of expertise than an electrician's.
