scubad3932
I have to add a recp. for a gas fireplace for the blower. Its on the 2nd floor and only way to get there is to pipe outside along the chimney then bore a hole into the old fireplace.
Question is, I am going to use PVC to go along the chimney but when I bore in should I change over to flex and let a recp lay behind the fireplace incloser.
nothing in the manifacture specs say anything...
