Gas Heater F/A Shutdown
MD88
Hello,
I have a gas heater that I want to shut off during a fire alarm, and it's controlled by a local thermostat. Can I just splice an addressable relay module into the thermostat wiring to cut the signal and shut the heater off? Any tips would be much appreciated!
Thanks
MD88
Awesome, thanks.
I was told by the HVAC guy that it needs to be shutdown, I'm not sure if it's by preference or necessity.
benaround
Arizona
Hello,
Thanks
If you want the fan to shut down the same time as the alarm, you would need to put the
module at the secondary side of the control transformer. If you open the t-stat wiring and
while on 'heat' the fan will continue to run until the temp. sensor opens the fan relay and
that could be a minuite or two. FYI.
iwire
Massachusetts
If you want the fan to shut down the same time as the alarm, you would need to put the module at the secondary side of the control transformer.
That is what I do unless the unit has factory fire alarm shut down terminals and they are becoming more common. :smile:
MD88
Oh, good point! This lovely unit has a line voltage thermostat, a low voltage control transformer for the fan (which specifically cannot be used for thermostat power - factory instruction) and no factory terminals for shutdown. So would I need 2 modules (I guess most of these come with 2 relays anyway) for this situation?
